Rover V8 oil leak at head gasket after rebuild
The torque wrench used, when was it last calibrated ??? Should be less then a year.
Even the one borrowed from a local garage should be calibrated every year.
New ones come with a calibration sheet also. Cheap ones without that sheet shouldnt'be bothered.
Have had cheap torque wrenches 30-50lb out of reach up and down.
'73 Ford F250, 6.7ltr V8
Building a GT40 mk2
Building a GT40 mk2
I dont understand why there are inserts in just he outer row of bolt holes ?SimpleSimon wrote:I just got to say they are some moody looking head gaskets you got there
I've used Elrings for years and think they are great. I can get them to leak, but only when I go silly on the power setup. And then they only leak when I've half metlted the block
- Seight-V8
I had this happen with mine, both heads leaked oil through the gasket, then down the block from the head faces, couldn't find the exact answer when I took my heads off, but I followed all the same precautions as everyone else.
and my gaskets where elrings.......
One thing to watch though is make sure your location dowels are not that high that they foul the heads, as I had to drill mine a little deeper due to the heads being heavily skimmed....
Just something else to watch out for.
I've had my block top hatted and decked now, I've had the block deck & head faces checked for flatness at work on a CMM to make sure both faces are good before it goes back together, then its cometic gaskets next for mine.
regards
scott
regards
scott
Cometic MLS gaskets are also great. I fitted a set to my last 4.6 build and then when I rebuilt the latest RV8 I went back to Comp gaskets. We put the Cometics on Jays Escort RV8 and blew the crap out of 3 or 4 engines and re used the Cometics 5 times with no leaks before we ritred the Escort last year.
When I fit comp gaskets to my Rover race engines I always used Copper head gasket spray adhesive. This glues the buggers on good and proper for racing
