Rover V8 heater connections
OK. If you have got room for that 'U', you can get flexible hose on there to wherever you want your heater. Just remove the U, and there are your two connections.
The small one with a bolt is the vacuum feed for an automatic transmission. Clearly not needed! You can hook up a vacuum gauge onto it if you want another clock on the dash that moves in an interesting way!!
The pic is a bit deceiving making it appear there is plenty of space available but I wedged the camera well down in the engine bay to take it.Bear in mind the original Wolseley engine in here was a puny 1500cc 4 cyl.The bulkhead has been moved backwards to squeeze the v8 in but still is maybe 4" forwards of a vertical line down to the heater pipes.
Muscle-Manta
Yes, so use that one to feed the heater. Use Muscle-Manta's 90degree elbow if it helps.Muscle-Manta wrote:The upper connection of the two pipes in your photo is where you have a straight flange bolted to your intake manifold. The 90 degree fitting I have in my photo is fitted at this same point.
Trace where the other pipe goes which should just be a straight run under the inlet manifold in steel to another flexible pipe to the water pump. Remove the flexible pipe, and reroute that connection wherever you like to give you the room for the valve.
Just bear in mind that if the thermostat bypass has been removed, that heater 'U' might be being used as a substitute, so if you put a valve in it, the cooling system won't work properly.
Maybe a pic or two of the rest of the cooling system would be in order.
Thanks to both of you for your patience.You probably realised by now that I am incredibly thick!Heres a pic of the front area(got me worried now about the system not working right when I add the valve!
http://i1374.photobucket.com/albums/ag4 ... 092299.jpg
Yes, that's stock. So you can just see the bottom hose from the rad on the left. Ignore that. Coming from under the inlet manifold into the water pump inlet is the heater return pipe (steel under the manifold, changing to rubber to the pump), which you could remove, and run your new heater return into that port on the pump. You would also have to 'tee' in that small other pipe, which presumably runs to the throttle body (it's an EFi manifold right?)
The other pipe which runs into the back of the water pump is the thermostat bypass, which you can just leave alone.
Sorry Chris had to go away.So are you saying that I can forget the join between the outlets at the rear of engine and merely tap into the pipe exiting at front of manifold? i.e remove pipe(the small one teed off is fitted to the metal outlet so will remain),come out of waterpump to heater then out of heater to pipe from inlet manifold?That would definitely be easier.
Mick
Mick
Hi Chris.Only just got around to starting this.Have removed the pipe in question.I bought some new defender heater pipes off Ebay very cheaply and they have come in very handy as they have a good length and bends of all sizes(even used an elbow for my pcv valve).I now have a nasty feeling I could be in for trouble!By placing the heater valve in one of the main feed/return water pipes to the head arent I effectively stopping the flow if I turn the heater valve off?Should I be thinking about fitting some sort of bypass?
No. The other pipe (that is just to the right in your picture) that runs from the inlet manifold (just below and to the right of the thermostat housing) to the stub on the back of the water pump is the thermostat bypass. That is always open. So you can block off the heater circuit if you want to (with a valve), with no problems.
