MegaJolt and EDIS
bobtail84
Post by bobtail84 »
Try opening the plug gaps some more.. EDIS will run with 1mm with no problems, in fact Ford recommend 0.75mm to 1.00mm
HTH
Jeff
Range Rover 3.9 with MegaSquirt and EDIS
www.essex-ms.co.uk
4.6_crossbolt
Post by 4.6_crossbolt »
OK, thanks. Might try the original plugs again with larger gaps, just as an experiment.
2000 (X) Range Rover 4.6 Vogue + LPG
1985 (B) Rover SD1 4.6, T5, LSD, SP+MegaJolt
1972 (K) Reliant Scimitar SE5A 3.5 V8 + quad SU's
SimpleSimon
Post by SimpleSimon »
bobtail84 wrote:Try opening the plug gaps some more.. EDIS will run with 1mm with no problems, in fact Ford recommend 0.75mm to 1.00mm
HTH
Jeff
I run 40 thou 1.1mm plug gaps no problem with EDIS since install :) I wouldn't advise you run with less than 35thou with EDIS anyway. 8-)
