Try opening the plug gaps some more.. EDIS will run with 1mm with no problems, in fact Ford recommend 0.75mm to 1.00mm
HTH
Jeff
MegaJolt and EDIS
4.6_crossbolt
- SimpleSimon
- Knows His Stuff
I run 40 thou 1.1mm plug gaps no problem with EDIS since installbobtail84 wrote:Try opening the plug gaps some more.. EDIS will run with 1mm with no problems, in fact Ford recommend 0.75mm to 1.00mm
HTH
Jeff
