TRS TA Performance Cylinder heads
Right. Must admit to not having come across an intermittent injector.
Are you using sequential injection? That would mean the ECU has one driver per injector. An intermittent fault (dry joint, etc) is more likely there. Or, of course, a problem with the wiring or connectors.
But wouldn't an ignition fault give the same symptoms?
Had a quick look at the Canems site and it appears to offer only semi sequential injection on a four cylinder. Which would suggest to me it has only two injection drivers. So on an 8 cylinder, that would mean four injectors being driven by each driver. So if just one injector was giving problems, it would suggest either that injector is faulty, or the wiring to it, rather than an ECU problem. Sadly, they don't seem to make their ECU schematics available, so it is just a guess.mgbloke wrote:The Canems ECU is quite basic I think It does have logging but looks pretty poor to me. In hind sight I should have gone for DTA or similar.
That's why I sent the car to the Rolling road, for the experts to diagnose and fix it. Wether it is fixed or will happen again we will have to see.
Document here suggests it has 4 drivers. Page 23
http://www.lloydspecialistdevelopments. ... 014CUX.pdf
Ah - right. But that would still mean two injectors per driver, so the same would apply.r2d2hp wrote:Document here suggests it has 4 drivers. Page 23
mgbloke wrote:Low end mapping and dwell.
I am really pleased with the way it drives.
Exciting times are ahead matey !!!
