chodjinn wrote:Awesome work mate. There are a lot of people who will be doffing their caps to you on this one fella!!
I'll be happy if it works ok so other folk know there is a budget alternative for this sort of upgrade Olly!!
The spool was free from Mike. But these can be had for around the £50 mark on ebay + P&P
The shafts were £83 each, but with the postage and taxes they ended up costing just over £350 delivered to my door. Which is still £150 cheaper than it cost me to have the old shafts custom made a few years back.
The bearings are more expensive if you buy them from the shaft guys in the USA. But they happen to be a stock item at my work and can be found on Ebay for around £9 each. And they can be trimmed to fit the MGB axle case at home on a grinder if you are careful as this is what I did.
Wheel studs were from Topspeed Automotive @ £48 for ten.
Wheel nuts were about £2.50 each from Northants Tyres in Aldershot.
Rear wheels were £63 each from the same place.
MGB diff bearings were £33 from MGOC.
Spare shims came in at about £24 I think (these had to be ground to get the mesh correct)
I dropped my mate at the machine shop £100 for doing the faffing around with the spool to make it fit the crown wheel and re drilling.
So the work cost me about £720 all in. Which I think has been a good result for me
The total is actually £800 with the oil and gasket and powder coating. But its well under a grand and it seems to have worked at the moment.
Now I'm going to test it until something breaks
Pel
PS!
The shafts are about £25 each cheaper in Australia, but Speed master would not reply to emails about shipping costs. I have a mate of a mate in Australia who is going to see how much it would cost to buy a pair and have them posted to him. Then work out how much it would cost by cheapest option to ship to the UK? They weigh in at 40lbs per pair.
