Hi all,i`ve just fitted a 14 cux hot wire based injection system to my 3.5 low compression Rover v8 and find that the vacuum at idle is around 10" mercury at around 800 RPM.
The cam is standard (I think) I would have thought that idle vacuum should be around 20" of mercury.
Has anyone got a vacuum gauge on their v8? If so could you let me know what engine size,cam and vacuum you have?
Have to admit that the car drives a lot better than it did on SU`s and that I may be over thinking things a bit.
MANIFOLD VACUUM AT IDLE.
j.johnson23
- Helpful or Confused
j.johnson23
My Megasquirted 3.5 gets a vacuum of 30-32kPa at in idle of 850rpm.
This is an absolute reading, and not a gauge one as engine off is 100kPa, and WOT is the same.
Engine is standard 9.35:1 compression, with 10 bolt heads, standard Rangey 3.5 Efi cam, hotwire inlet manifold, and flapper plenum.
No idea how kPa converts to mercury though!
1974 Rover 3500s
1984 3.5 90
1959 2.25 series 2
1984 3.5 90
1959 2.25 series 2
j.johnson23
