I'm an Italian owner of a Range Rover MY1990 3.9 V8 EFI (+LPG).
Since last year I have lots of problem when the car is running with petrol.
With LPG everything is ok, but when i switch to petrol the sound of the engine becomes not like a V8, the car has no power (i have to use 1st low gear for road where usually i use 3th high gear). The engine idling is non regular and from the exhaust comes out drop end black smoke…
In this year i have done:
- Check timing (with strobe lamp)
- new stepper motor
- new fuel pump
- new MAF (used but working)
- new fuel pressure regulator
- new sparks
- new wires
- new ignition coil
- new injectors
- new petrol temperature sensor
- new water temperature sensor
- new vacuum, rotor and cap of distributor
I have no more ideas about how i can fix this problem
with LPG the car is very good, with petrol…sucks!
I'm waiting for the cable to use rover gauge, but I do not have much hope…
