RV8 Flywheel/Flex Plate to Crank Bolts
- topcatcustom
Can someone please tell me the bolt diameter and thread please, are they 7/16UNF? The 6 that hold the fly/flex onto the crank.
TC
Re: RV8 Flywheel/Flex Plate to Crank Bolts
Correct.topcatcustom wrote:7/16UNF?
- topcatcustom
I use ARP bolts from Real Steel Tom.... Make sure you order Flex plate bolts though as the flywheel bolts are a different length.. That was my first mistake yonks ago
- topcatcustom
- topcatcustom
