Anyway to outline the problem:
Bit of History, I bought a 1987 Range Rover V8 EFi as a base vehicle for a project. Whilst stripping it down I dumped the entire wiring harness and the EFi unit as these weren't required as I went down to the bare chassis and instead fitted a set of SU carbs and electric fuel pump etc.
Now since I stripped out the old ignition I needed to fit just a very basic home made loom to fire the V8 back up. However having done this and as the title of the thread describes we can't get any spark when we turn the engine over. Lots of head scratching has gone on checking the loom etc.
We've fitted a new dizzy and coil (matched set) thinking the module was done for as I've done a major amount of welding and thought the massive amount of current may have creamed it. But still no joy.
The first thing that springs to mind is our home made basic ignition loom and whether we've got it right or something missing? It probably something really simple but you know how these things go when you can't see the trees for the wood so I'd be glad for any suggestions of something we might have missed or lead us in a different direction to check out other details. Even a members basic ignition diagram might be worth a look just to make sure we've got it right.
Cheers all Simon.
