So the problem appears to be the use of stainless steel bolts. As I had an M6 SS nut between the fuse terminal and the cable terminals on both ends. SS is 4 times more resistant than steel therefore the SS is acting like a heater element and it got hot. It also accounts for my voltage drop.
I cannot test this theory until I get the car started and that's awaiting some gauge senders due sometime but at least it all calculates out. Something I did not think about when using SS bolts / nuts.
Ammeter Confusion
- richardpope50
- Gold Member
- richardpope50
- Gold Member
The bolts are M6 (it's a close up photo) and there was an M6 nut between the fuse contact and the cable ring terminals so the current went though 5mm or so of SS twice. A friend calculated the resistance and it more or less equalled the voltage drop I got. Just goes to show what can happen when you do not think of such things.
Richard.
