As above , i,ve done a bit more work to my P6 . I posted on here a year or so ago when i uprated the oil pump and timing gears . That was as far as i could afford to go at that time . The intention was always to go back and fit SD1 heads , new cam/lifters .
Over the last few weeks that is what i,ve done , i collected the parts over 18 months or so as and when i had spare pennies ( o.k the old man had to have jam sandwiches on occasion
Any hoo , work done , up and running again , with the cam ( 3.9 landrover ) run in to the correct procudure with Millers 20/50 oil . The heads are 3.5 SD1 of 1983 vintage , chemically cleaned , checked for flat and within tolerance , and i laped the valves in . Tin Gaskets . I used these http://www.ebay.co.uk/itm/RANGE-ROVER-L ... 1c18205564
My reasoning being if they are no good i could always destroy and remove them with a decent pair of long nose pliers , obviously i couldn't of fitted them after if i decided i wanted to !
So basically it runs lovely , with a smooth tickover , strong low down and roll on top gear acceleration ( auto ) with a nice purposeful growl which is
all i was looking for . The only issue is a slight puff of blue smoke on hot restart after it's ben stood for a while . It clears straight away and uses no oil . the rest of the time it is totally clean . I've only done about 100 miles since and not given it a good long run . I'm wondering if it will carbon up a bit and get better Thinking on everything was chemically cleaned ( heads ) or is oil sitting on those seals then running down as it sits
If the pics upload then the one of the rocker gear was waiting for my P6 baffle plates and did go together with them
[/img]
[/img]
[/img]
