- Checked /re-calibrated ECU temp gauge and compared to multi-meter – it’s pretty accurate.
- Start engine from cold and just idle at 900 rpm
- Cabin heater pipes warm first as expected
- Radiator keeps cold until thermostat opens
- Thermostat opens around 80
- Engine temp rises to 94 and otter switch for first stage (Kenlowe) fan comes on.
- Temp holds at 93/94 but does not decrease
- Closing cabin heater valve made no difference
- Rad core where fan is, is cold to touch. Outside fan area too hot to touch.
- Rad input hose read 88, output read 72 so some 16 degrees drop.
- Raised revs to around 1,700 rpm for a few minutes and temp slowly climbed.
- Second stage fan came in at 95 and temp still slowly climbed reaching 98 when I switched engine off.
Went for a run and generally much the same with temp climbing to 100 when we stopped to cool down.
So, the problem seems to be not enough water flow especially when revs increase. I’m unlikely to have air lock except possibly just in short section of top hose. So what’s wrong?
Options?
1.) I have wondered for a long time if there is enough belt length driving the pump. It’s only three or four inches of contact. However belt does not appear to slip – no leak, no squeal, no bearing noise, all firm and no polishing of pulley nor belt face.
2.) Are pump impellers so rusty / corroded they cannot shift water? Engine only 44,000m and stored empty of water for recent years. Before that was on road for six years so probably had antifreeze to protect it.
3.) Blocked waterways? Not much rust coloured water comes out.
Questions:
1.) Is a 16 degree temperature drop across radiator about right?
2.) How can I check if the pump pulley is slipping?
Any other comments appreciated.
Radiator is a 65mm deep core, fan is a high capacity two stage Kenlowe 12" fan rated at 1,250CFM and 1,850CFM at second stage.
