I can't now as its all boxed up to go back to SC Power on monday to see what the problem is,
at least if its a bracket etc they can get it sorted,
Supercharger should be back with me on Wednesday
and hoses arrived today,
so started sorting out the remainder of the boost hoses, and started work on the throttle bracket setup,
Rover v8 efi throttle assemb too long,
hoses,
Throttle bracket cut to length,
How the bracket now sits prior to welding,
hoses,
its blue not purple
Right charger came back from SC Power today and now spins nice and free, even when bolted up back to the engine
Rad now fitted and plumbed in bottom hose was a mare and aint pretty, but if it works and don't get hot in traffic I can get one made in silicone etc over the winter months,
Bottom Hose,
Top hose made and welded, just needs polishing now,
At last the bulk of the boost hoses finished,
just need to get the air temp boss welded in the ally 45 bend by the intercooler, some how made an air filter fit, and fire her up
she will be fine mate
did the email come through?
don't worry about that bit as in the email they are mounted to the axle not the base plates,
Just out of curiosity, did you get the SAME blower back or another one?Coops wrote:Right charger came back from SC Power today and now spins nice and free, even when bolted up back to the engine![]()
I am always suspicious with things that need to be returned to suppliers to be made to work and then get sent back with no explanations of what actually was wrong.
Yup same charger back
Was to do with the bracket a couplw of thou out and pulling everything pissed when tightened up. Sweet as a nut now all bolted up and turns nice.
Also i may od been over tightening the bolts thriugh the bracket to charger
Here's an idea of some standard practices you should consider adopting for fasteners......
http://www.swtc.edu/ag_power/diesel_eng ... values.pdf
http://www.imperialsupplies.com/pdf/A_F ... Charts.pdf
cheers for that,
Welded up the throttle assemb today at work, came home and fitted it all, and we now have a fitted working throttle and pedal and a calibrated TPS
Just need to find a bolt/bung from somewhere to go in one of the threaded holes in the base (same size as the servo take off)
one of these bolts:
unless someone knows the thread size???
one of these bolts:
and I must pull my finger out and sort some sort of air filter for the charger too lol
