At the moment the rod linkage goes as far as the engine, then there is a cable from the kick down linkage on the original rod linkage which runs down the back of the engine and back up under the heater to the carb.
Bit messy - pic from when I bought the car
Found this one too - I have an idea that it is a kick down linkage from some random V8 powered car/4x4, but don't know which one?
I don't think there is a problem with engine movement, but am prepared to work on that if required. Thanks for the links Kiwicar, but none of them seem suitable
Yes, I get that bit, but the rod linkage already goes to the engine, prior to transfer to the cable, so any movement translation would be there already.
The P6 was designed with a rod system which does not have a problem with movement translation so I am assuming (yes I know the saying ) that they have sorted this problem, and as I am just connecting to the end of it, it won't be a problem.
I am just looking to tidy it all up as this part of the engine bay annoys me
A - sorry, missed out the P6 bit. Of course it already has a rod system - including that rubber bush in the bulkhead which is always shot. Trying to remember - doesn't the gearbox control cable bit fit to the cylinder head or inlet manifold originally? I'm sort of wondering why that too is a 'bodge'.
It looks like the original owner cut the bar off just in front of the kick down bracket, then welded the kick down onto the bar. The bar would just fall out the back at this point as it is no longer held by the carbs, so he wrapped a piece of heater hose around it and secured it with a jubilee clip.
Not sure why there is an extra piece welded onto the black bracket on the inlet mani? but then the cable, used for a throttle cable, was bodged onto the kick down.
If I can get the L shaped kit in the picture of other people's cars, I can dispense with the cable, cable bracket on the back of the carb, butchered bar and kick down, bracket on the heater where the knackered bush usually resides, and the black bracket on the inlet mani.
It would look a lot nicer and I would be less worried about the whole thing falling apart.
I've made my own now. And the car is a lot more responsive, and a pleasure to drive. It was good anyway, but the improvement by just getting rid of the slack in the throttle linkage is quite remarkable.
I used a 20mm box section, strengthened with some 16mm tube to form the base. Then a 1/4 UNC bolt through the back to hold the pivot, and an L shaped lever that I cut out of a 6mm sheet of aluminium.
Perfect job - OK it could look better, but I only have a hacksaw, file and a drill so not so shabby
