I'm sure this has been asked many times before, but what is the interchangability on the Rover V8 heads?.
Will the HRC2479 replace the standard heads on a 1984 SD1 carb engine as long as they are fitted with composite gaskets?. Same goes for the HRC2210 heads - what would be the benefits, if any, of using these heads over standard SD1 items on a very mildly modified 3.5 engine (9.75 pistons, 3.9 Range Rover cam)?.
Thanks.
Cylinder head interchangability 3.5 3.9 4.6.....Etc.
