twin turbo rover v8 twin carb afr ratio
What should be ideal afr ratio please? Whilst its sat ticking over and the lc-1 is plugged into laptop its showing high readings (18) but this does drop when throttle is pressed, I'm going to test drive tomorrow to get true readings on boost etc when engines warm.
Idle around 15:1 maybe 15.5:1 but really whatever gives you a stable idle without hunting. As long as when boost comes it goes to about 12.5:1 then at Idle you want it as lean as it will go and still be stable. If it is draw through then the atomisation and mixing should be very good so it should be able to burn nice and clean and not build up carbon deposits.
thewedgeshop.com
I can't get my 4.6 lump anyway near 15:1 at idle, it has a reasonably hot cam and very free flowing exhausts which probably don't help. (Neither does the Eddy carb!). Anyway it's fine at 12.2:1 and goes rough if I lean it off to 12.5:1
I don't have any turbos to mix the air and fuel up either! Dunno why I posted really!
I'd be very surprised if you had a stable idle at 15 or leaner.
Idle, anywhere between say 13.5-15.0:1 would be acceptable. 13.5 may not pass MOT or be borderline, but it would be a good strong idle mixture
On boost. Many variables, ie boost, compression, intercooling etc etc.
12.0-12.5:1 may be fine on a low boost application running nowhere near knock/detonation. It absolutely would not be fine running more boost or with higher charge temps etc.
11.0-11.5:1 is a fairly generic safe target for most builds whilst on boost.
Mine is most happy with AFR at 12.8 - 12.5 at idle. 11.5 at full pedal.
- SimpleSimon
- Knows His Stuff
Smaller 4.0 with lairy cam and minor mods wont idle smoothly unless at 13.5 or richer, any leaner and it runs like poop and makes the cam sound splashier than it issidecar wrote:I can't get my 4.6 lump anyway near 15:1 at idle, it has a reasonably hot cam and very free flowing exhausts which probably don't help. (Neither does the Eddy carb!). Anyway it's fine at 12.2:1 and goes rough if I lean it off to 12.5:1
SimpleSimon wrote:Smaller 4.0 with lairy cam and minor mods wont idle smoothly unless at 13.5 or richer, any leaner and it runs like poop and makes the cam sound splashier than it issidecar wrote:I can't get my 4.6 lump anyway near 15:1 at idle, it has a reasonably hot cam and very free flowing exhausts which probably don't help. (Neither does the Eddy carb!). Anyway it's fine at 12.2:1 and goes rough if I lean it off to 12.5:1
I don't have any turbos to mix the air and fuel up either! Dunno why I posted really!splashier! is that a word?
I bet your Mega squirt is allowing you to run it leaner than if a carb was fitted. For example I can not run my cruise any leaner than 15:1 but I know of engines with squirters that will go much leaner, oh well I still like my carb!
Er you don't live in or near Wokingham do you?
