MGB rear axle conversion to disc brakes?
chodjinn
Post by chodjinn »
I'm currently thinking of swapping out my shortened SD1 axle for an original MGB, but I don't want to run drun brakes. Has anyone converted such an axle to disc brakes, if so what did you use?
Devonrod
Post by Devonrod »
http://www.mgexp.com/phorum/list.php?40
your bound to find something here-
Re: MGB rear axle conversion to disc brakes?
chodjinn wrote:I'm currently thinking of swapping out my shortened SD1 axle for an original MGB, but I don't want to run drun brakes. Has anyone converted such an axle to disc brakes, if so what did you use?
Neat work, Dave!
unstable load wrote:Neat work, Dave!
Thanks - must get round to fitting them to the actual car. No garage - so want a few days guaranteed good weather. Never happened last year. :(
DEVONMAN
Post by DEVONMAN »
Hi Dave,
When you do fit them, switch the bleed nipple to the top outlet to assist bleeding.
They were probably oriented at 1 o'clock not 3 o'clock on the original car.
Regards Denis :D
chodjinn
Post by chodjinn »
Looks good, what calipers are they and what diameter/thickness disc are you running?
Sierra Cosworth/ Scorpio. Discs are 21mm.
chodjinn
Post by chodjinn »
DaveEFI wrote:Sierra Cosworth/ Scorpio. Discs are 21mm.
They're the sierra 4x4 ones right, as the 2WD ones aren't vented?
Think so.
chodjinn
Post by chodjinn »
Don't supposed you have a template for that bracket do you? Is that 10mm steel plate?
I was gonna weld something on like my current axle, but that looks a lot better.
