How much damage to my 1/4 mile ET?
So the TVR runs the 1/4 mile in 12.4 @ 111 NA with 275 @ wheels.
With the standard 3.45 diff i am at about 5000 rpm in 4th as i run the traps.
I pulled the leaky diff out this weekend and John Reid is rebuilding it for me with 3.08:1 gears. So motorway cruising will be more civilised with the possibility of a whopping 30 mpg.
I also want to do a vmax event and the extra gearing will come in handy.
But what effect will this have on the 1/4 mile. Looking at the gearing i reckon i can now do the 1/4 in 3rd gear getting close to 6000 rpm which is a smidge over my peak power.
We will see at York come Easter i guess.
10.612 @ 129.77
176.5 standing mile.
If you give the clutch enough stick off the line then if anything you should be 1/2 to 3/4 second quicker by virtue of cutting out 1 gear change, but really it is down to you, can you bring yourself to launch at 5000 revs and and slip the clutch until you have matched the road speed to the revs? Ahh I love the smell of burning clutch in the mornings . . . it smells of. . . Saxo!
Ps you could always fir t 3 plate 4.5" tilton then you can give it as much stick as you want, just don't try ar drive it in London!!
Talking of clutches
This is mine after less than 1000 miles.
Pressure plate looks bad but feels ok to the touch
Flywheel badly scored
The damaged flywheel weighs 11kg. I will get it skimmed. Will a rebalance be necessary?
I have another flywheel whick weighs 12.4kg but the face is undamaged.
What do you reckon? Use that? Get it lightened?
10.612 @ 129.77
I am not the person to ask if it is a good idea to lighten a flywheel I have seen one let go . . . in all cases I would say no, skim it to get a flat face, ballance it if the skimming takes material off a counter weight OK, but lighten it, only if you are not that attached to your lower legs.
If you want a lighter flywheel then get a lightweight Steel or Ally one they are much cheeper than sorting out what you are left with when a lightened 30 year old piece of work hardened Steel/ iron lets go.
As regards the clutch, look into a 4.5", 5.5" or 7.25" tilton multiplate on a flexplate or even a full on drag clutch with centrifugal counter weights and an apropriate gearbox.
I would go for a steel flywheel every time, after killing a flywheel up the pod a few years ago, something about the clutch wear dosent look right, the wear looks uneven across the pads, should the flywheel have been machined for a raised platform for the friction surface???
I ran a Helix conventional clutch on my cortina with 300hp and no problems at all,
THE SMOKING GNU
Of more concern, why has the clutch got into that state in such a short period of time ?
Have you been slipping the crap out of it ?
1/4 is hard to judge. It will depend what traction you have, and how far each gear drops you after a change. Sounds like it could be a fairly substantial rpm drop which might put you in a crappy place, which will cost you time.
Launch wise, the taller gearing might actually help with grip. So ET may be the same, but trap speeds lower.
stevieturbo wrote:Of more concern, why has the clutch got into that state in such a short period of time ?
I confess.
I fitted this clutch towards the end of the season last year and met a few mates at Shakey for RWYB. I still havent got round to fitting the linelock so i was reversing into the bleaches and dumping the clutch then left foot braking for the burnouts. This worked ok until i 'forgot' and used my old technique of heal and toe. I guess the MT streets and rear brakes on were too much and i spun the clutch for a good few seconds before i realised. Still ran 11.4 on the gas tho but i guess the damage was done.
10.612 @ 129.77
Probably a combination of not having the flywheel refaced when i fitted it and maybe not enough beddig in period. I maybe did 300 miles normal driving on it. I have over 300 bhp NA but i also race using nitrous that takes me to upward of 500 lb/ft and an organic plate just cant cope so thats why i had to fit the paddle kit.ian.stewart wrote:I would go for a steel flywheel every time, after killing a flywheel up the pod a few years ago, something about the clutch wear dosent look right, the wear looks uneven across the pads, should the flywheel have been machined for a raised platform for the friction surface???
10.612 @ 129.77
dbv8 wrote:Talking of clutches![]()
Why is only half the pad worn?
stevieturbo wrote:But you're automatic...isnt quite the same.mgbv8 wrote:My diff is 3.07:1 in the MGB Del.
What sort of rpm do you see from launch through to finish ?
It used to be manual Stevie. This is the stock MGB V8 diff ratio with 4 speed + O/D gearbox.
They had to inhibit O/D in 3rd gear on the stock box because it had too much torque and would damage 3rd gear.
With the same diff on the auto I launch at 2000rpm in stage and then shift at 4500 rpm in 1st and 2nd. Then just let it run to about 5200 rpm across the line for my low 10 second runs with a 2800 rpm stall converter and 28" tall tyres.
