The other question is whether to use the range rover pipes which have a filler tower on the return from the heater matrix to the water pump. I had planned to, but its so much higher than the pressure cap on the rad im not sure if it will cause problems?
SD1 rad is core size approx 610x440mm and 30mm thick
Alloy rad is approx 660x360mm and 40mm thick
Radiators. SD1 on left, Nissan on right
Nissan expansion tank
Nissan rad cap which will go to expansion tank
Range rover heater pipes and filler tower
