Was a Paxton supercharger conversion, now a Rotrex C38-91
Reg,
thats the ones i use when on gas, or 8's when i run a bigger hit,
I was sure I seen 8's listed somewhere.
And you should not use non-resistor plugs on a car with electronic controls. ie EFI.
So B7ECS or similar non "R" plug is not ideal.
The resistor helps to suppress interference
r2d2hp
Post by r2d2hp »
Do you mean Resistive Stevie. Opps re read your post and your saying we should use resistive
I changed to BR8ECS as you can not get the 7 in resistive
THis does not refer to V8's but details the plug type and benifits http://www.ngksparkplugs.com/pdf/dyk_es ... _plugs.pdf
There are dozens of 7 heat range plugs that are resistive.
BCPR7ES, BCR7ES are just two off the top of my head. But there really are loads with different letters and combinations, and of coruse over different brands like Denso which is a 22 heat range.
Or you could go platinum or iridium
PFR7B would be a double platinum, or BKR7EIX for a single iridium which is a bit cheaper and what I'm currently using on my LS.
Although I'd been using some cheap 22 Denso before that, cant remember the part number though
Interesting about the electrode though. It would only apply to retracted nose plugs, ie very cold.
Some of the very expensive racing plugs have a similar electrode, although it's just straight rather than bent.
Cant really see anything like that needed on an RV8 though. I know I only ever used fairly normal plugs and never had any issues.
BR8 ECS plugs ordered today,
I dont really have any sensitive electronics so I use B8ECS in the MGB.
These plugs take a shed load of abuse on boost and nitrous or both.
Coops!
When you see the 8ECS plug you will notice that it looks a lot like a chopped plug that WoN suggest ?
i did have some, but think the wife threw them out in the move :(
blower belt arrived today,
plugs will be here in the morning,
more pics now in the garage section,
as its more of a build now not advice:
http://www.v8forum.co.uk/forum/viewtopi ... 8525#88525
Return to “Forced Induction”
