Can I turn my rad sideways ?
I've a narrow width opening, but all the rads I can find are wide.
The rads i am looking at have ports on left and right, so would end up top and bottom, so seems fine.
But, is there anything inside the make up of a radiators elements that means they can't be tuned on their side?
Jon
Jon
It took me a second to understand what you meant. You want to rotate the rad by 90 degree's dont you?
As Denis say's. As long as you chuck the hot water into the top connection it should be fine.
My old MGB rad has the headers top and bottom. But most modern cars have the headers on each side. I cant see a problem with this
Regards
Perry
Regards
Perry
Jonny m wrote. --Just wasn't sure if there was anything in the make up of a horizonsl rad, that might have prevented it being turned to vertical[/quote]
Some modern crossflow rad have internal dividers which make the coolant flow left and right more than once before exiting. You are unlikely to have one of those. It should be obvious under inspection of the end tanks if there are any internal dividers. Poke a wire carefully through the hose inlets/outlets and you should be able to feel and dividers if they are there.
Regards Denis
Regards Denis
