Thermotime switch thread size
Hi guys, does anyone know what thread the thermotime switch is and coolant sender ? I need to make up an adaptor to put the coolant temp sender in where the thermotime went originally. Cheers
Re: Thermotime switch thread size
M14x1.5demo2 wrote:Hi guys, does anyone know what thread the thermotime switch is and coolant sender ? I need to make up an adaptor to put the coolant temp sender in where the thermotime went originally. Cheers
It's only Imperial where part of the original engine. The injection was designed long after that and is basically Bosch which uses Bosch sensors which are metric. It would have been very expensive (and pointless) to have had specials made with Imperial threads.
The threads on the main engine are Unified. They are closer to American than Whitworth or BSF, but not strictly speaking the same. They came about during WW2 so things could be made the same on both sides of the pond. Most UK car makers adopted them after WW2, but not all. Especially if the design was basically pre-war.
