Front cover / water pump swaps
Camo
Post by Camo »
Hi guys,
I think I have decided to go with the Range Rover v8 from my 97 P38 in the Moss, question is can I swap the front cover and p6 water pump etc from the p6 to the RR engine ?
Won't need all the fancy power steering etc and space is a premium ..
Stu
russell_ram
Post by russell_ram »
yes, but . . .
you'll also need sump and oil pick up pipe to match from a non X bolt engine (sump front bolt pattern is different), cam swap to one that will take a distributor drive, a spacer to take up the extra length of cranknose that will poke through th old P6 crank pulley which you have to re-use and a couple of other things I've probably forgotten.
Russ
I would keep the P38 front cover, just ditch the ancillaries you don't want and get a shorter belt.
That front cover is very compact already.
DEVONMAN
Post by DEVONMAN »
ChrisJC wrote:I would keep the P38 front cover, just ditch the ancillaries you don't want and get a shorter belt.
He probably needs to use a dizzy.
Needing a dizzy is all in the mind - they are an abomination.
Dizzies Rule :lol: :lol:
mgbv8 wrote:
ChrisJC wrote:
DEVONMAN wrote: He probably needs to use a dizzy.
Don't you bloody start!, you'd be into the 9's if you dumped that bloody clockwork fangled device!
Ha Ha!! CLOCKWORK :shock:
I love it :)
