Powerlite Starter Motor 318
Camo
Post by Camo »
I am needing to get a small starter motor for my Moss project, this one is ideal if you ignore the price, but Does anyone have experiance of these ?
My question is can it be put on either way, ie solenoid up or down ?
http://www.autoelectricsupplies.co.uk/p ... tegory/139
I need the solenoid down for it to fit... If its not able to fit either way I need to rethink the whole steering column rather tahn starter size..
any advice is welcomed.
Stu
SimpleSimon
Post by SimpleSimon »
Can't help on the fitment side but, but this may have the kind of config your after :D couple of the TVR boys use em and seem happy enough 8-)
Camo
Post by Camo »
Snug as a bug, fits with at least 5cm clearance on the column.
Stu
SimpleSimon
Nice, must say I do like a reduction gear starter 8-)
Migwell
Post by Migwell »
I use one myself, no they cant be fitted either way, they are available but different part numbers and one is more expensive than the other.
Did have a problem with mine to start with, was very noisey on disengaging from the flywheel, had it all checked, teeth, depth etc, even had it changed but was still the same, after a month it quietened down and has been fine ever since, that was 2 years ago, works great but is slightly louder on spin over than the original.
Got mine from Rimmer Bros as it was easy to get changed had I had a problem which they did easily.
