First job will be engine out again to find out why the Saab clutch release keeps leaking when I bleed it
Then it's replace the head bolts with studs and new comp gaskets to try and fix the oil weeping from the head gaskets - even though all I've done since building it is fill the thing with oil via the rocker covers. The engine hasn't even run yet
