My capris latest.
No you don't need one. All it does is raise the idle on a cold start and keeps the idle constant when hot. Without it your really no worse off than having a carb idle wise. For the cold start idle you could fit a Bosch thermostatic valve that is fitted to the flapper system and also to the ford jettronic as fitted to the 2.8's and stuff like that. Its nice to have and makes it smoother obviously but no real deal.
- ihatesissycars
- ihatesissycars
Quick update, axles in and everything (i think) is attached to it. Everything is filled with fluid and most of it is staying there too. Errrr, All the electrics are done except for running a wire to the a.f guage in the car.
Just need to put petrol in it which i would've done if it weren't for the fact that my jerry can is full of two stroke mix dammit!
Heres some pics.
It normally sits lower than that at the front byt about 2" but theres some spring raiser rubber things on it at the mo to make it easier to get in and out of my garage.
The s**t hole i have to work in!
Heres some pics.
kev_the_mole
- ihatesissycars
- ihatesissycars
- ihatesissycars
ITS ALIVE!!!!!!!!!!!!!!!!!!!
It runs! Sort of. . . . .
All my settings were wiped from the ecu when I plugged it in (except it knew i had edis) somehow but it ran almost instantly. I need to generate a complete msq (or find one from someone) and then i can get cracking with the interesting bits!
gav, i got my req fuel at about 13.2 m/s
i have a copy of my lambda and ve tables some where if you want to copy,
as our engines aint far off from each other,
i cant send you my .msq as not sure if my vems one will work with megasquirt
- ihatesissycars
- ihatesissycars
bill shurvinton
- Getting There
