Hi folks. I have an MGB with a Rover V8 out of a P6. Can anyone advise what sort of oil pressure should I be seeing when the engine is hot?
Chris
Rover V8 Oil Pressure
8-10 psi at hot idle @ 900 rpm is quite common on a worn engine. This can often be imroved by doing some work on the rocker gear.
