Long time lurker, first time poster.
I have searched the forum but I just need some pointers in the right direction.
I've been building what started out as a Historic Rally car replica of the 1974 UDT Marina V8 Coupe. It has evolved/devolved slightly but due to time and costs I've not yet done the rally car livery bit only the mechanical parts.
I started out using a Rover P6 engine and auto box (yes not very rally like!) but it was clear this engine was too tired and so I've now brought a 3.9 Discovery (interim) engine that I intend to fit to the P6 auto box
My first question is this: If I retro fit the front cover of the P6 to the 3.9 what kit will I need for the oil pump to match the discovery distributor? I have found two kits online that some posts have pointed towards, one with a spacer but I have also found another that doesn't include a spacer but states it will work with the later dizzy.
Without spacer:
http://www.simonbbc.com/ignition-spares ... emale-type
With spacer:
http://www.rimmerbros.co.uk/Item--i-RB7480
My second question is relating to the auto box: The discovery engine was from an auto but will my P6 flex plate, torque converter and started all swap around? Will my kick down cable mate up with the EFI manifold?
I would switch to a manual but finding everything needed for the conversion, i.e. flywheel, clutch, bearing, release arm and slave is quite a job in one package at a reasonable cost. Maybe next year?!
And my third and final question. For now anyway!: Will my P6 pulley bolt over to the 3.9 crank with or without a spacer for the bolt? I did read that these interim engines have the same crank but because of the difference in timing covers it may need a small 20mm spacer so the bolt can tighten up?
I really appreciate your time on this.
I've now got 6 weeks to finish the build and get an MOT!
Regards,
Ben
