where do the pipes go ?
medwaykent
medwaykent
help
dont know how to download pic anyone help ?/
medwaykent
thx
thx dave will try but probably beyond me !!!
medwaykent
hopfully uploaded
http://i1270.photobucket.com/albums/jj6 ... 16.jpg[url] hope you can see pipe outlets where do i connect too ? is one directly below dashpost overflow ? and other breather ? also in pic there is small outlet in centre of manifold just below black pipe .. also does it make a difference if i have a 10mm fuel pipe feeding carbs or should it be 8mm thx in advance...[/url]
medwaykent
medwaykent
What you're looking for in the post window ismedwaykent wrote:http://i1270.photobucket.com/albums/jj6 ... 0_2116.jpg
Doing that to your URL gives:-
The small connection on the manifold between the carbs is a water jacket connection - it should have a pipe to the top of the radiator.
According to my SU Carburettor manual, the brass coloured connection is 'crankcase ventilation connection' and the silver coloured one is 'vent tube'. So I suppose you can blank off the 'vent tube' one and connect the other to the rocker cover breather (via a flame trap maybe)
