Fancy getting his name wrong ?? Shame on you Mike
As we discussed in a previous mail Del, sorry Derek
Adjust those dampers to resist bump on the rear and rebound on the front.
This will help weight transfer quicker off the line. But it will put more load on the tyres so they need to be really sticky from a proper burnout. (line lock ????) Another job eh
If you have enough adjustment to make it launch better and the tyres dont hang on you will be drifting through 1st and 2nd gears. Your rear tyres are a bit hard on the side wall so will be unforgiving if they let go off the line.
I dont know how much adjustment you have at the mo but for a start I would say take 50% out of the bump adjustment you have left on the back and about 75% of the rebound adjustment you have left up front.
Your car is less likely to suffer hard body roll like mine does off the line so the irs is ok. You just need to tweak stuff around it to improve things while still keeping it good for road and circuit as you can mark your adjustment points.
If you are happy that the clutch and drive shafts are up to the job you should be able to nail that 10 without making serious mods.
You only need 0.3 off your present PB to make a 10.95 ???
You can do this in the 60 foot......
And get that bloody nitrous controller fitted so you dont have to faff with the button. Thats losing you valuable time on the 1/4 as well...
Regards
Pel (Perry)
