megasquirt air temp sensor
Just wondering where u ms guys have located the air temp valve on the rover? near the airfilter, near the plenum?
Also does anyone know what thread it is?
cheers
cheers
mine lives here Biatch
One I bought was M18 x 1.5. Pretty common thread for this sort of thing.demo2 wrote:I allready saw that pic sliag, so does any1 know what thread it is?
Im gonna try and do away with the y piece in the intake so it has two hoses straight into the airfilter housing, cant see the point of having 2 pipes squeezing down to one now dont need a/f meter.
- SimpleSimon
- Knows His Stuff
- daxtojeiro
- Forum Sponsor
I would keep it away from external heat sources if possible, as it can alter the tune if it gets heated from the exhausts.
I always recommend the air filter if your in doubt, but thats only for NA applications,
Phil
Phil
Interesting, Phil. Are you implying the original Lucas position on the SD1 - ie inside the flapper - was less than ideal? This does get some heat from the exhaust manifold especially when stationary. Might explain a few things...daxtojeiro wrote:Hi,
Phil
Would it be better in the air filter on one of these? At the moment mine is in a tube which replaces the flapper, but would be easily re-positioned.
- daxtojeiro
- Forum Sponsor
HiDaveEFI wrote:Interesting, Phil. Are you implying the original Lucas position on the SD1 - ie inside the flapper - was less than ideal? This does get some heat from the exhaust manifold especially when stationary. Might explain a few things...daxtojeiro wrote:Hi,
Phil
If youve got no issues where it is then leave it alone
If it is going lean due to heat soak, youll notice this when you sit in traffic for a while or if you turn the car off, then re-start the engine after 5 mins and it goes lean until youve driven for a while. If it does that then move the sensor
Phil
