Im gonna get a blue light under it too, i took it down too a garage and they put it in thier ribo wash, came out like new then had it clear powdercoated.
this is what i made when i saw an old crank going rusty an needed a table by my sofa for beer/coffee!
it sits perfectly just above the sofa arm, photo doesnt dot he top justice, its got a perfect machined finish, kind alike like the bottom of a vinyl. alloy top an stainless bottom.
demo2 wrote:Thats smart, takes up little room, i would have kept the journals natural tho.
it was a quick throw together job from my behalf, i just gave the crank to a friend who builds huge pontoons an the like an he had it sprayed at an industrial coating place so its just blasted an painted with very tough paint.
the base i cut out at work an got a friend to polish it up an the top another friend machined it up, cost me nothing al looks alot more befitting than some ikea crap!
Risky wrote:I've got an old engine sitting in my garage and I was going to do a V8 table too. I noticed it is the high compression.... 10.5?? or something, is it a "rare" engine or worth something more than stripping/scrapping?
It's the pistons that set the CR on an RV8, so unless these and the bores are good, it's just another old engine.
I've got several blocks /cranks I could use to make furniture BUT
they're not grandchildren friendly are they . I will need to wait afew years
Mr. Cautious
it is a P5 /P6 block, an early version of the 3.5 worth it to someone restoring a p5/p6 to original spec, not desirable otherwise. The heads are asthmatic even by rover v8 standards, the block has the least webbing and is about the weakest and it is a rope seal crank, no not very desirable, sorry.
best regards
best regards
In that case it'll be either a coffee table or down to the scrappers...more likely the latter!
