hotwire injection stalling problem
maximotorsport
Post by maximotorsport »
ok peeps
I have a 14cux injection system with a tornado mark adams ecu, the problem i have is that when you rev the engine and back off the throttle the engine stalls unless you ease the revs back down, could this be an air leak somewhere or is it more likely to be a component problem, this is fitted to a comp safari racer if that helps
Any ideas...?
thanks
SimpleSimon
Post by SimpleSimon »
Do you have the idle stepper motor/valve fitted?
maximotorsport
hi, yes i have that fitted so i can flick a switch to use it
