Oil pressure relief valve piston removal ; help needed .
dogdog1
Post by dogdog1 »
Hi , Can anyone tell me how to remove the piston from the oil pressure relief valve on a Rover V8 , before I start gouging at it ? Thanks .
spend
Post by spend »
If its in-situ I normally find a slight twist & wiggle with a ball-ended allen key is enough to gently tease it out.
Engine in place and still have oil?
Crank it over on the starter - it should pop out
ikari1
Post by ikari1 »
How did you get it out in the end? Mine is being a real byitch too!!
dogdog1
Post by dogdog1 »
I never did !
SimonAspin
Post by SimonAspin »
ikari1 wrote:How did you get it out in the end? Mine is being a real byitch too!!
When mine was stuckin they apparently blew it out with an airline, and a magnetic tool to move it about, not sure where the airline attached never asked :roll: when it came out it had a very slight burr on it.
Simon
