Otter Switch for Fan
leylandracer
- Helpful or Confused
Just looking at this topic, im having the same problem, New switch fitted but not working, if i bridge the connector the fan will come on, Mine is fitted into a hard pipe between the thermo and rad, what interested me was "The swirl pot isn't mounted on rubber mounts is it?
That would be good enough to lose the earth connection." the pipe on mine is mounted on rubber P clips so there isnt a direct contact with the chassis? Would this cause a problem?
leylandracer wrote:Just looking at this topic, im having the same problem, New switch fitted but not working, if i bridge the connector the fan will come on, Mine is fitted into a hard pipe between the thermo and rad, what interested me was "The swirl pot isn't mounted on rubber mounts is it?
If you are using a switch that makes its circuit to earth through its body then having it cut into a hose will stop it working unless you run an earth wire from the housing to a chassis earth point.
I've had 3 guys at the race track in the last 2 years with the same problem on new builds. I quite like the look on their faces when I come over with a jump lead and they get fans running or in one case oil temp gauge working
leylandracer
The coolant set-up is more or less standard apart from the rubber lined P Clips, speaking to a auto electrician freind the other day he reckons ((without seeing it to verify), your switch will just be joining a wire together via a thermal contact, therefore does not need an earth etc. It has two wires, & these just make contact. If you join these two & the fan runs, everything you need is there, just the switch is not connecting)
Any ideas
Dont know if the pics help, you can see the switch on the 1st pic.
Any ideas
leylandracer
If bridging the switch contacts makes the fan run, then either the stitch is faulty or not getting hot enough to make. There can't be any other reason.
So remove the switch and try it in boiling water. If it is ok, have you measured the temperature of the swirl pot? Could be perhaps an airlock somewhere?
- richardpope50
- Gold Member
I eventually tried my new one in boiling water and it worked just fine. I am now wondering if it was simply because the engine (water) did not get hot enough and my gauge was very inaccurate.
My car is all stripped down at the moment so in a few months (or so!) when it is back together again I'll see if it works in the car. It is obviously a simple problem!
Richard.
leylandracer
- richardpope50
- Gold Member
Agreed. My Otter switch is in the swirl pot about 40cm of silicon pipe from block exit whilst my gauge is off usual temp sender. IIRC the gauge was well over 100 and on the way to 110. To me that's too high assuming it is accurate - a CAI unit.DaveEFI wrote:The coolant where the gauge sensor is could well be at a different temperature to where the fan switch is?
I'm just wondering if I need a lower Otter switch setting or probably try and get an accurate temp reading first, I suppose.
Richard.
leylandracer
