Still not right!
auction1st
Still not right!
After some great advice from the forum I've got all 8 firing but its not all good news
When I've tried to balance the su's the r/h carb is drawing a lot more air than the left? I've checked the damper and the butterfly all seem ok, the only way I can seem to get an even run on all 8 is to blank the breather from the rocker top to the R/H carb. Has anybody got any sugestions or is it time to find some replacement carbs?
there should be some sort of flame trap in the pipe between the rocker cover and the carb that also acts as a restrictor to air flow. got anu holes/ splits in the pipe?
Have you detached the linkages and ballanced the carbs on the end stops for the butterflys? The next stage is to reattache the linkages and check that idle tey are not holding either carb slightly open, finally adjust the linkage stops so the throttle linkage opens both throttles evenly.
best regards
best regards
The SU carbs will work perfectly provided you have the breather system on the engine set up correctly.
Did you fit the breather at the rear of the lifter gallery? Let me know if you have because now with both SU carbs drawing additional air from each rocker cover via their respective flame traps, you will now be in a position to balance the air flow.
Ron.
Ron.
4.6 Rover 3500 P6B
auction1st
