I bought a set of (Perforated steel faced) Manifold gaskets a while back (From a ebay seller) a nice fit but on the V8D Stage 1V heads/ports theres a slight lip at the bottom of the port, should i make do? or would it be OK to file a bit off the gasket?
Hope that makes sense
Steve
Maifold gaskets, PERFORATED STEEL FACED, slight lip
leylandracer
- Helpful or Confused
softdash3.9
leylandracer
Just remove the material from the gasket to match your exhaust port size on the heads.
leylandracer
