no stamped on piston
andylamb
Post by andylamb »
need some help opened my engine up tonight
stamped on the outside edge of the piston
60 69 62 P C
anyone enlighten me as to what these mean
cheers Andy
DEVONMAN
Re: no stamped on piston
Post by DEVONMAN »
andylamb wrote:need some help opened my engine up tonight
60 69 62 P C
cheers Andy
Hi, What engine is it ?
andylamb
Post by andylamb »
sorry rover 3.5 think its sd1 (not in a rover car now)
11A10078
9.35 1 C R
andylamb
Post by andylamb »
also need to know the socket size
& direction to slacken crank shaft bolt
cheers folks
Dunno about size, but the crank pulley is undone in the normal way, i.e. it's not a left hand thread.
Bloody tight though, you'll have to lock the crank somehow.
I have a 12v impact driver - came from Maplin for about 20 quid. It takes 1/2 sockets. It sort of spins up to speed then whacks the socket in an undo direction. Moved the pulley bolt on my auto RV8 no problems. It's officially for undoing wheel nuts, but I've found it useful for others. Think the spec is 250 ft.lb or so.
ged
Post by ged »
andylamb wrote:also need to know the socket size
cheers folks
15/16" AF or 24mm & anti clockwise.
Regards Ged
