the reason i ask is i need a rwd gearbox for my v8
any other suggestions
Yup. Early 4HP22 were cable control only - later ones some electronics, so get the right one.dandan81 wrote:hi guys if i was to get hold of a BMW zf4hp22 gearbox can i change the bell housing from a range rover zf4hp22 gearbox on to the BMW one,
any other suggestions![]()
how do i go about changing the input shaft from the car gearbox to the range rover one is it a easy jobDaveEFI wrote:Yup. Early 4HP22 were cable control only - later ones some electronics, so get the right one.dandan81 wrote:hi guys if i was to get hold of a BMW zf4hp22 gearbox can i change the bell housing from a range rover zf4hp22 gearbox on to the BMW one,
What vehicle is it going into?
I'm not certain, but I'd guess the Rangie torque converter would fit the BMW box. So you'll need the bellhousing, TC, drive plate and spacers, etc.dandan81 wrote:how do i go about changing the input shaft from the car gearbox to the range rover one is it a easy jobDaveEFI wrote:Yup. Early 4HP22 were cable control only - later ones some electronics, so get the right one.dandan81 wrote:hi guys if i was to get hold of a BMW zf4hp22 gearbox can i change the bell housing from a range rover zf4hp22 gearbox on to the BMW one,
