rebuilt 3.9 v8, ready to be run up.
slight coolant leak from gasket /head running down onto the block under no 1 cylinder.
Tried a short bolt in outer (unused ) bolt hole, no difference.
Any ideas or is it a strip down and new gasket ?
3.9 coolant leak
lightning53
Re: 3.9 coolant leak
sowat wrote:rebuilt 3.9 v8, ready to be run up.
If its leaking coolant from cold without being run then DONT run it !!!!
You need to fix the leak first....
It may just be some crud on the mating faces. If you run the engine the water system pressure will rise and the leak will get worse. Dont risk any damage for the sake of finishing the job off properly.
Get the head cheacked to make sure its flat.
- SimpleSimon
- Knows His Stuff
+1mgbv8 wrote:sowat wrote:rebuilt 3.9 v8, ready to be run up.
