Run smoothly and pulled well but left wondering where the hell the power had gone.
Answer: It is there, just the motronics still thinks its a 4.0 and is trying its hardest to produce 4.0 power.
Have read everything, everywhere as a little stubborn to ask and low and behold it was under my noise all the time.
In the work shop manual is the following found it when look up how to adjust the throttle linkage .
The V8 engine is equipped with the Bosch Motronic M5.2.1 engine management system. This system is a sequential
multiport fuel injection system controlled by an Engine Control Module
A single ECM is used for the control of the existing 4.0 litre engine and the new 4.6 litre engine introduced with 03
model year vehicles for the NAS market only. The ECM contains the tunes for both engines variants. When the ECM
is replaced, TestBook/T4 must be used to select the correct tune to match the engine fitment.
Well off to the dealership tomorrow and will post results.
Hope this helps others who are think of doing the change.
kev
