3.9 V8 on SUs.How much power?
I am planning on putting a 3.9 into my 110 v8.I am keeping the carbs and the engine will be rebuilt to standard specs.How much power can I expect from that set up and will there be much difference to the low comp 3.5 already in?I would leave the 3.5 in but the bottom end is getting a bit noisy.Nick
- Getting There
Stick in a real Steel Viper Hurricane camshaft, keep the airbox and filter (but feed it with cold air from behind the right headlight) and fit BAC needles in the carbs and it'll fly! Good torque through the range with a power increase from 3000rpm.
Ought to give around 190bhp (or 200 with a little head work) and 220 torques.
- Getting There
It's meant to be a straight fit, but I normally buff about 2mm off the top of the guides as I always have the heads off at the same time anyway. Std springs are fine, some fit the -1 coil ones for safety. Pull the heads, fit composite gaskets, replace all the stem seals at the same time then you can buff 2mm off each stem for safety and peace of mind.
A friend that I built an engine of this spec for reports better mpg than the original 3.5, in a G-WAC discovery.
