1 Turbo or 2?
1 Turbo or 2?
I know of a quite a few TVRs that have taken the forced induction route to bigger power and i fully intend to do the same. Some have quite expensive blower set ups but i am leaning towards the turbo option.
The question is 1 or 2? I have seen success with both options but need to decide which way i want to go. Would 2 help for bigger power and less lag?
I would like to think i can treat my low compression forged piston engine to at least 1 bar of boost and ultimately 20psi.
10.612 @ 129.77
176.5 standing mile.
I guess two would be best for a neat installation eh ??
Dont forget the Pro Charger option
Quite compact and no lag with them is there???
Talk to John Eales as I saw a TVR Pro Charged engine in his shop a while back. I'm pretty sure it was for a circuit car. I'm sure I posted a pic of it on the forum not long ago !!
For me the blower was the cheapest option. Carb off, blower on, carb back on. Move rad forward 1" and fit the pulleys
OH MY!!!
That is a work of art mate... GET ONE!!! GET ONE NOW !!!!
Eann has developed this set up to sell as i kit. I am sure the price will be fair but i need to save fast.
There are some excellent twin turbo set ups also. I will try and get some pics.
1 i know of is a nice DIY job using 2 scooby turbos producing 490 lb/ft but tailing off quickly after the peak for some reason on only 10 psi. It is still a work in progress but looks promising.
10.612 @ 129.77
Is it a Garrett GT35 or just a GT35 - the later probably being a chinese clone.dbv8 wrote:GT35 on fleabay delivered from the states for $400.
I need to learn what else is needed.... ie to build a shopping list and the work involved.
edit - found them. NOT Garrett Gt35's. So quality is unknown and you can assume that you cant rebuild them. But for $268 its worth a punt if only for mockup!
Real GT35:
http://cgi.ebay.com/ebaymotors/Garrett- ... ccessories
Clone GT35:
http://cgi.ebay.com/ebaymotors/GODSPEED ... ccessories
Just incase you haven't seen this here is a link to Garret's site with info on turbo sizing. Very interesting.
http://www.turbobygarrett.com/turbobyga ... ch103.html
My understanding is that a properly done twin turbo setup = greatly reduced lag over a single turbo; unless you go for a twin scroll or variable geometry unit.
Personally I would lean towards a twin setup (space/money permitting) for a road/hillclimb car. Single unit would be suited to straight line/circuit work where you need maximum HP at high RPM and you won't be lifting the throttle frequently.
No point in a big turbo that makes massive hp if you're still waiting for it to come on boost by the time you get to the next corner.
Also, I highly recommend this book:
I have this and the 4-stroke version. Very good reads (note he also prefers superchargers for road use because of the instant response.)
I'm personally keen on the supercharger + electric clutch route but would take twin (parallel, not sequential) turbos over a single.
As always thought it comes down to how well planned and executed the setup is. A well designed and implemented single turbo setup would be better than a compromised twin unit setup.
I'll just add that I have never built a forced induction setup so am commenting from research + experience driving other peoples cars with various types of forced induction.
