Resleeved 3.9 and forced induction
Some bad news from my part; the engine I have doesn't have top hat liners in, its just a standard 3.9 (gonna get engine number to check whether its a proper 3.9 or a resleeved 3.5).
Good news I found out where my other short block is, which has a new set of standard 3.9 liners in. The bloke who's built it said its no good for forced induction applications as a resleeved block has a high risk of dropped liners in such a case.
I can understand the thinking, but how true is this?
On a second note, anyone want a new 3.9 short block?!?
- ihatesissycars
The first engine that was blown in my old car...
Was an early Rovercraft "4.0" which was a 3.5 block, re-linered to 3.9.
It was blown for a long time with no block issues.
If they are concerned about the block if using forced induction...I wouldnt even be using it n/a
Right finally spoke to the engineering firm. This is the chronology of events according to them (whom I implicitly trust compared to the engine builder):
1. 3.5 Block brought to them and fitted with 3.9 liners (standard)
2. Returned to engine builder, put in car, blown up a few weeks later.
3. Engine builder asks for top-hat liners to be put in block, blames engineering firm for dropped liners
4. Engineering firm says they wouldn't have done the standard liners if they knew it would be for forced induction (contradicts what Stevieturbo and others have said). Refuses to reline block again until paid (still unpaid)
5. Block has remained on the shelf since (over a year)
Now, I still have to find out what block I have in my garage (fingers crossed its a late 3.9 but i doubt it). Either way, I'm probably going to get top-hat liners put in one of the blocks.
- ihatesissycars
- ihatesissycars
- ihatesissycars
Thats my other block thats going to become a 4.6. The bosses on the side that are circled lightly are where the holes for the cross bolts can go, ignore the arrow at the front.
The pics of the caps show the difference between them and the standard non crossboltable caps.
This is the 3.9 block that can house the 4.6 crank after some work, there is and slightly earlier one that has the bosses in the block but has the earlier caps. This one can't be crossbolted and if you wanted to fit the 4.6 crank you would need to turn the mains down rather than line boring the block out as the earlier caps don't have enough meat in them to take the larger journal.
- ihatesissycars
Have you considered just staying with a 3.5 block and capacity? The 3.5 blocks are pretty much unburstable aside from the main cap fretting fault. If you were to find a good condition early block (which you probably have already) crank and rods (which again you prbably already have then get some forged pistons and arp main studs (about £800 from v8 dev's) you'll have a very very very strong bottom endcapable of supporting some proper power and no (touch wood) reliability problems.
yeah I have thought about that. There's a guy running a single turbo TR8 in Oz that's pushing 500bhp on standard internals - including pistons! I think the block/heads were O-ringed though - but that donesn't cost a fortune over here.
I know the block down south is my original 3.5 SD1 Vitesse block. Two of the liners have slipped, so its junk at the moment unless I get top-hats put it. Bonus though it already has ARP mains in it, and the crank/rods have been race balanced.
What I considered last night is holding out for some Group A rods as well - the same set has come up on ebay twice and not sold. I had also considered Forged Pistons - for the same price as sorting a late 3.9 + the 4.6 bits, plus the re-linereing, I could put the money into the pistons for the 3.5/3.9 and have a bombproof bottom end, like you said.
Certinly food for thought tho. I don't mind sacrificing capacity for the sake of some forged pistons in a tophat block. Nice!
- ihatesissycars
You have a 3.5 block with a slipped liner? Blimey!
Anyways, use some standard efi rods but get them recon'd by real steal, they basically blueprint them and put arp bolts in them (they very very very strong already), recon a crank, get some forged pistons and arp studs. It really should be bomb proof but the key thing is you don't have to fork out £1000's on relinering a block and then getting some forged pistons to suit that block. Doing it this way means strength and no liner problems and less money.
All 3.9 blocks have potential to go wrong like the 4.6 blocks.
