Hi All,
A bit more info then may help
Its a IBG Block from John Eales, bore and stroke take it to 5.2, it uses a 3.9 serpentine front cover (Dizzy type) and will be fitted (I think) with std water pump viscous fan and cowlinhg to suit.
The radiator is already a bigger than std version, thuis engine is going in my Challenge 90, which wioll then be shoved into feet deep mud and goo, and given beans - the result with the 4.5 JED I have at the moment is it gets super hot, and thats also with 2 x 16 inch fans on the rad, and exit holes for exsseive heat on the backs of the wings
Basically I know this engine will be a tad tricky to keep cool in this sort of environment - rad can get covered solid in mud etc, so I am looking a ways to add additional cooling to keep things under control ?
My knowledge / memory says either cool water or cool oil, both effect heat, and if poss both, but use a stat or 2 to ensure doesn't overcool ?
It aleady has a huge rad, that on its own won't be enough, inc the 2 x existing fans, the cowling will be used to help direct every possible air flow not to escape.
The front cover has been modified by John, the oil filter screw on area is cut away and tigwelded closed, then a "In" and a "Out" Aeroquip male 1/2 BSP (I Think) fitting is placed there, the can be send them to a remote oil filter (Longer pipes = more oil = help in cooling) but I was thinking of an oil cooler as well, and hence the thermostat - I have no idea of the options ?
I am also listening to a friend, he says fit a electric water pump, which will control the flow to aid cooling etc ? EWP is it ? are these as good as he says ?
Any help will be gratefully rec'd as I am bnearing finish of the build, and don't want to then stop and do a U Turn on cooling systems !
HELP
Nige
