Initially it was going to be Efi, that's how the donor came but as usual things change!
What may be easy to some seems a bit harder to others, ie me!! so bear with me on my struggle to fit this together.
I need to know how and where to join the hoses. I've read a fair few threads on here and now it seems just a bit more tricky. I want to get it right and the best set up I can.
Pictures should help with descriptions so here goes. Any advice greatly appreciated.
Thermostat housing and I take it Top hose goes to top of Radiator. The small pipe off bottom is differant/not there on the Efi one? What is it, where does it go?
Connection coming up out of the inlet (between the looped rubber hose) what and where to run it?
2 connections out the rear of water pump. These connected to a pipe that ran under the EFi manifold and out the back to what I assume fed the heater? What and where to connect to now? There appears to be nothing to remount the pipe that runs underneath the inlet manifold?
Rear of manifold...obviously something missing, what and where does it go to?
These hoses are running under the Efi manifold, do I re-use them or is it a case of re plumbing. I read that the steel tube can rust away so best change it/mod it?
What gets used from here?
Apologees for what to you guys may be easy but i've never attempted anything like this before so i'm learning as I go. THANKYOU.
Phil.
