This is a stock rebuild with EFI, standard new cam and original valves
Gathering all the info I can and allowing for correct terminolagy,would the following be correct-
Smooth out the Exhaust port, lose the ridge down from the valve seat area. Match to exhaust manifold, but keep it roughly the original size and shape
Match the Inlet port to the inlet manifold, but leave mostly that as cast.
Bullit end valve guides
Get the valve seats 3 angled, and lap in valves
Heads have been skimmed, and pick up the die grinder tomorrow
