The engine made some funny noises so i shut down and coasted to the exit gate in a smokescreen.
She pulled the best she ever has up to the point the gasket popped. My steel implant held up. But cylinder gasses got in between my repair and the liner to blow through to the water way and under my repair out the side of the block !!
The engine stopped itself as I went under the gantry as it was water logged.
The launch had the best power yet which means I will need to tighten up the slapper bars as I got tramping and she tried to steer from the rear like she used to do before the slapper bars.
Watch the vid and check out the ET for a pss with no power for the last 300 feet? I'm well happy with this result. So now its time to put the good block in at last. I will also need to check my engine bay wiring on that side of the engine bay. this will make sense when you see the video
I'll post up pics of the damage later..
http://www.youtube.com/watch?v=zbWCXq33rRY
