New project
Hi Mark
engine spec,
all forged bottom end 383 chevy with Marhl flat top pistons
Dry sump oil system
RHS 235 port 64cc chambered heads with 1/4" over length valves to take .7" lift
11.6 CR
comp cams 4/7 swap mechanical roller cam, 256 inlet 263 exhaust duration on 112 LSA giving .688" inlet lift, .660" exhaust.
isky tool room springs with rev kit, should let it rev to about 8400
sheet metal inlet manifold with 2X autonomics throttle bodies (many thanks Mark and Ian)
It will have mechanical methanol injection and megasquirt for sparks and engine logging.
2.03 first gear powerglide (standard case) with transbrake and 35 spline output shaft and a 3500 stall converter.
4.11 crown wheel spool with 33 spline shafts in an aftermarket case
Once that is running I will add a 6-71 blower, fit the glide guts into a TCI case and if I have the cash upgrade to a 4200 stall bolt together converter.
engine spec,
Dry sump oil system
11.6 CR
Hi Mark
yes methanol will allow alot more compression, I've been told you can run around 14.5-15.5:1 N/A with the cam I have, and with 11.5 and a blower I should be able to run about 24+ lb boost easily, I will start at about 18-20lb boost to be on the safe side.
best regards
best regards
Hi Iain
Happy new year to you
I think I shall take that as a compliment, especially from a chap who sits 1/2 an inch off the deck hanging onto two bits of string with a kite on the end whilst trying to steer the whole contraption with his feet!
I am looking forward to "interesting times"
Hope you are well
Hope you are well
Well actually getting on with things, I now have a drilled engine plate mounted in the chassis, I have made a top for the inlet manifold to take the two throttle bodies, just need to get two 2" spacers to go under the throttle bodies and get a linkage and that will be pretty much done. I hope to get the powergilde next weekend which will let me temporerilly mount the engine and box so I can sort out where the cross tube and diagonals go in to support the rear of the 'box. I'm still trying to decide what steering box to use, VW beetle, VW campervan or another, I am keen on any surgestions here for any steering box that is reasonably light, easy to mount (the Beetle one is not that straight forward) and a sensible price.
I now have the engine plate shimmed square in the chassis, front engine mounts cut out, all aligned with the centre of the chassis and the pinion centre of the back axel, and the gearbox centre line, all checked with my laser spirit level. I picked up a pair of centrelines last weekend. Yesterday I took the axel case off to Andy Robinson to have all the guts fitted and the case cut to length.
The remaining chassis tubes are cut and notched ready to weld in, when I have mastered my Tig welder
Not come up with a decision on the steering box yet, still after any surgestions.
- topcatcustom
Hi Tom
with a rack I would need to come up with some way to turn the motion through 90 degrees to operate the 12 foot long steering arm!, I am not contemplating having a 15 foot long steering column so I can mount a rack at the front of the car. . . good idea apart from that detail
Hi Chaps
some pictures of progress, yes it may not look much for 6 months work, but you would not believe how many brackets I have welded on. It also seems everything I have to do needs designing first. I have also done the front axel brackets (Roy built the axel) and the steering box is now mounted.
I now have the mechanical fuel injection system, another gearbox, Coan racing one with a straight cut 1.8:1 first and a 5500k stall converter (er yes it is a very high stall
Anyway pictures
Anyway pictures
Thanks Al I am finding it quite a slog at the moment, I cannot believe how many brackets I am welding onto the thing. . .
I now have a mechanical injection set up, a powerglide and torque converter. I want to get the engine and box trial fitted soon, but I am still a way from that yet.
Thanks again
Thanks again
